Can buy an adapter for just about any battery tender that will plug into the rear outlet. Have a cetek and a genius that I use.
The one I mention in #13 of this thread has the plug in (shown in the picture). Are you in YYC? If you are then it’s at Jack Carter Chev Parts Dept Desk ... Schumacher ... Amazon sells a similar one (however not sure). I do use my GM maintainer like the one you are getting but I do like the Schumacher as it comes with all the options.thanks trying to find a plug in type to the unit in the trunk
No but about 1 hour driveThe one I mention in #13 of this thread has the plug in (shown in the picture). Are you in YYC? If you are then it’s at Jack Carter Chev Parts Dept Desk ... Schumacher ... Amazon sells a similar one (however not sure)
This is the Jack Carter Chev one ...
I get it for about $95 - charges 6V & 12V
And knows just by being attached to one.
Tested and works on Cadillac and GMC Yukon plug ins too ...
View attachment 21619View attachment 21620View attachment 21621View attachment 21622
yup … deleted my posts as they were temp … so I can set up a post to refer others too when asked … thxThink he already bought the “Corvette” one Spence.
Bleach on a rag the wipe the tread on the rear tires would have made it a lot easier..Just like having ice radials..Won't be any problem letting it run for 10 minutes Ita vette. Do like I did.....once.... Backed it out of the garage (warm tires)... into the snow outside my door... Took at least 10 minutes to get it back in.. Still thanking my wife for pushing... She did raise an eyebrow when I gave her a microfibre towel to push with... hahahaha
Yoikes ... my black t-shirt's worse nightmare that is not discovered until the next wash ...Bleach on a rag the wipe the tread on the rear tires would have made it a lot easier..Just like having ice radials..
Good tip I had never heard of before. Yes. Back in the day I used significant amounts of bleach for the tires on my cars but that was for a totally different purpose.Bleach on a rag the wipe the tread on the rear tires would have made it a lot easier..Just like having ice radials..
ITA Vette,i was told to start it up once and a while and let it run for a bit....Some folks say no...Now im confused
Without knowing 2006 Corvettes, I expect there are remote terminals under the hood, in expectation of accesss for convenient boosting or charging. I know that is the case with brother-in-laws 2012 Camaro.My apologies if I'm posting this in the wrong place, I've just recently purchased a 2006 Z06 and the battery is located in the trunk. What is the best way to setup a trickle charger for the winter? I have purchased a battery Tender for the car. Thanks in advance for any help.
C7 and C8 come with battery maintainer ( OEM option). Maybe there is one for the C6?Without knowing 2006 Corvettes, I expect there are remote terminals onder the hood, in expectation of accesss for convenient boosting or charging. I know that is the case with brother-in-laws 2012 Camaro.
I have run CTEK battery tenders on all our winter stored vehicles including the lawn tractors with never a problem come spring start up time. I've been putting cars away since 1972 and before the battery tenders, I just disconnected the battery for the winter and took the battery into the house where it was warm.As you've asked for information on a "trickle charger", I'm trusting that you want to maintain the charge during periods of non-use and / or for winter storage. If that's the case then, as previously stated, any name brand, solid state, automatic battery charger/maintainer with a charging current range of around 1 to 3 amps should do the job.
The OEM charger that can be purchased as an option from GM is made by CTEK, their model 3300. If purchased with the car it's $115.00. The same charger/maintainer can be bought from Amazon Canada for around $90.00 but you will need the 12V port adaptor, CTEK 56-263, if you want to use the rear 12V outlet in the car. It's an extra $22.00 so you are close to the price of the OEM charger. If you can buy from Amazon US it's much cheaper when it goes on sale.
I bought the NOCO G3500 and the adaptor from CT when it was on sale for around 87.00. It's a true "smart charger" and has enough amperage to bring back a fully discharged battery without overcharging. Lots of other features but I bought it primarily for winter storage. Great specs and good value.
There are many other products from CTEK, NOCO, Schumacher and Battery Tender that will do the job.
Best regards
Ross
Here are my experiences with battery maintainers.I have run CTEK battery tenders on all our winter stored vehicles including the lawn tractors with never a problem come spring start up time. I've been putting cars away since 1972 and before the battery tenders, I just disconnected the battery for the winter and took the battery into the house where it was warm.
