Michelin Consumer Care [mailto:
[email protected]]
Sent: November 12, 2017 7:40 AM
To: [email protected]
Subject: Thank you for contacting Michelin regarding case number:13010756
11/12/2017
Hello James,
Thank you for your email. We welcome the opportunity to serve you.
In regards to the email you sent stating:
I store my car for approx. 4 mth in my garage -attached to my house. Do I need to do anything to the tires other than make sure they are properly inflated? It is my understanding that tires now a days do not need to be off the concrete to prevent flat spots. I have been storing cars over the winter for 20 years and have never had a problem with my tires.
I will be happy to assist you with your question regarding storage, James. What we recommend for tire storage is if the tires are not used for a prolonged period of time, remove the tires (mounted on their wheels) and reduce their pressure to half their normal value to store. Store tires in a clean, dry area, away from direct sunlight and above 0°C (32°F) in accordance with the information provided by Michelin in technical documentation or their website.Do Not use, store or handle the tires at ambient temperatures below -10°C (14°F). Under these conditions the tire components can degrade, resulting in reduced performance, and at low temperatures can lead to cracks in the tire compound and hence reduce potential in use.Never use a tire with cracks, breaks or damage to the sidewall or tread. I hope this was helpful!
We appreciate your business and thank you for choosing Michelin.
