- Jun 16, 2019
- 13
- 10
I installed it this last winter, and have been using it this spring/summer. With this kit you need your CD trunk changer to be working, and there are 2 options of kits. The kit I bought is to still use the CD changer, but the other option was a AUX cord, and your changer won’t work.
Installing was easy. Take console out, take stereo out, unplug plug from back of radio that goes to the changer, and this plugs in. You have to run a power wire to the fuse box.
It always connect to my phone perfect, and fast. I have a old iPod with a ton of tunes on it, and it works good. One thing, you can only have one phone hooked up to it at a time. When you want to use the Bluetooth option, you just push the “CD” button on the radio. So if you are listening to the radio or CD and a call comes in, you have to push the CD button to answer the call. It has a little wired external mic that I have on my console beside my shifter, and it works good.
Hope this helps.
Hope this helps.
