Solar power for roof tops
Get back to you tomorrow.
Hi . There is no requirement regarding any aspects of an installation other than the work being done by a qualified electrician, permit, inspection and meeting the requirements of your supply authority. So , pertaining to storage the small sheds may be because they are using lead/acid batteries which when charging give off hydrogen which has to obviously vented . The only way to go these days is to utilize lithium ion storage batteries which although expensive are worth the cost for a number of reasons . They have come down in price lately though and it’s WELL worth shopping around and getting competing quotes. The costs to resellers and contractors is considerably less than the end user pays of course. In some cases up to 50% . I was a distributor of renewable energy products for a number of years so am quite familiar with this . Same applies to electrical materials in general.
The number of batteries is limited only by your budget. The more you have the longer your run time when the ice storm hits. Without storage you’re in the same boat as the neighbours If there is no wind and the sun goes down. I would also recommend more solar as opposed to a wind turbine If you’re a fan of birds ,lol . Although a wind turbine will work at night when panels are sleeping. Don’t be concerned about those saying that lithium ion batteries are dangerous due to thermal runaway. If properly installed and protected from damage there is no issue. They are as I mentioned expensive but so are deep cycle lead acid and the lithium will last longer plus you can utilize up to about 90% of their capacity per charge cycle as opposed to at the best 55% for the alternatives . Hope this helps.
I installed solar panels on my rooftop a few years ago, and it has made a big difference. My electricity bills have gone down a lot, and I feel good using clean energy. The installation was pretty simple, and the panels have been reliable. If you’re thinking about going solar, adding panels to your rooftop is a great option. It’s an easy way to start using renewable energy and can save you money in the long run.
Have you calculated the payback time relative to total installation cost ? Are there feed in tariffs in your area. In other words are you able to feed excess production into the grid for a credit .
I installed solar panels on my rooftop a few years ago, and it has made a big difference. My electricity bills have gone down a lot, and I feel good using clean energy. The installation was pretty simple, and the panels have been reliable. If you’re thinking about going solar, adding panels to your rooftop is a great option. You can check out some reliable providers like solar panels dublin. It’s an easy way to start using renewable energy and can save you money in the long run.
Solar panels last a long time—20 years or more—so the upfront cost can really pay off over time. If you’re in a spot that gets hail, it’s worth thinking about ways to protect them, but otherwise, they’re pretty low-maintenance.
If you end up generating extra power, there’s a lot you can do with it—charge an EV, heat a pool, or even run a greenhouse.
When I was looking into solar for my place, I found https://solarsmart.ie/ really helpful for figuring out what would work best.
