Schiffer won’t release at the park only once in a while after hitting the break it will but most the time it’s locked and park.
Hi Hydroguy. Where are you located? If you are in the Ottawa area, I can come over and show you how to fix this after purchasing the replacement switch online.
There are many workaround, but I chose to actually change the problematic switch. I had purchased 4 of them, but sent 3 to other Corvette owners, after I replaced mine successfully.
Cheers,
Peter
