Do Corvette Bodies Still Use Fiberglass? It's Complicated — Jalopnik
Its low weight and durability led Chevrolet to choose fiberglass for the body of the first Corvette, in 1953. Does Chevy still choose fiberglass today?
Sort of . As far as I can find there is only 400 lb of steel in a C8 . Engine crank, connecting rods ,valves, and exhaust as well as brake rotors which is all I can think of, except for perhaps some fasteners .So the point of this is that driving in areas where salt is used on the roads shouldn't be a worry from a rust standpoint . Happy New Year !CFRP currently. SMC before that, and fibreglass in the earliest models.
Or, was this a rhetorical question?
Aluminum doesn't lose mass like steel. Also it mostly just pits or tarnishes.I'n not sure how well the aluminum framework is sealed up , but road salt will cause corrosion on aluminum.
Actually my build was delayed slightly due to an aluminum shortage. Fall 2023.For sure . More aluminum used than anything. View attachment 136196View attachment 136197
Apparently it depends to a great degree on the type of alloy used . There are " marine " grades " which are more resistant than say the aluminum in your storm door. No idea what GM uses though but I suspect regardless that the degree and rate of corrosion would be less than steel.Aluminum doesn't lose mass like steel. Also it mostly just pits or tarnishes.
Interesting. Thank you for sharing.![]()
Its low weight and durability led Chevrolet to choose fiberglass for the body of the first Corvette, in 1953. Does Chevy still choose fiberglass today?apple.news
Maybe I should start to drive mine in the winter as salt isn't used here at all. Then again I'm not sure if it would like -40 degrees ambient........I'n not sure how well the aluminum framework is sealed up , but road salt will cause corrosion on aluminum.
That is why they make AWD SUV so you can keep the C8 for decent weather.Maybe I should start to drive mine in the winter as salt isn't used here at all. Then again I'm not sure if it would like -40 degrees ambient........![]()
Just plugged in my Tundra although it's only-32 this morning. It still only needs about two hours of juice to not to be too cranky starting. That's a battery blanket and block heater. I keep the battery tender plugged in 24/7 in the cold weather though. Got my C8 out April 15 last spring so only another 14 weeks, lol. Sim rig till then to scratch the itch . This looks amazing at 4K with HDR on an OLED . Plays amazing as well if you have the hardware to run it maxed out.....That is why they make AWD SUV so you can keep the C8 for decent weather.![]()
I've worked with Fibreglass before and I would have guessed why the switch. Fibreglass is a pain. Literally. If one gets the glass particles on oneself it is itchier than hell. It's terrible to work with.![]()
Why Did Corvettes Switch From Fiberglass To SMC Body Materials? — Jalopnik
The first Corvettes were built with fiberglass bodies, and the fiberglass stuck around for two decades. Here's why Chevy switched them to sheet molded compound.apple.news
True that. When I built my first house I had a small local insulation company to do the install. He didn't use a mask or coveralls or nothing. I asked him about the fiberglass issues and all he said was " I stopped getting itchy after a few years and no one can say my lungs aren't pink"...I've worked with Fibreglass before and I would have guessed why the switch. Fibreglass is a pain. Literally. If one gets the glass particles on oneself it is itchier than hell. It's terrible to work with.
I start to scratch when I see the truck from the building supply company driving past with a load . That's why I had my garage insulated with spray foam when I finished it. Nasty crap that pink .I've worked with Fibreglass before and I would have guessed why the switch. Fibreglass is a pain. Literally. If one gets the glass particles on oneself it is itchier than hell. It's terrible to work with.
Ya, I used rock wool in my basement. "Safe and sound ® " in the basement ceilings and spray foam when we renovated the house.I start to scratch when I see the truck from the building supply company driving past with a load . That's why I had my garage insulated with spray foam when I finished it. Nasty crap that pink .
Rock wool is much better than pink, higher R value and easier to install for sure. And no itch ! Good for hydroponics as well if you use the right type.Ya, I used rock wool in my basement. "Safe and sound ® " in the basement ceilings and spray foam when we renovated the house.
