Rust proof ?
CFRP currently. SMC before that, and fibreglass in the earliest models.
Or, was this a rhetorical question?
Sort of . As far as I can find there is only 400 lb of steel in a C8 . Engine crank, connecting rods ,valves, and exhaust as well as brake rotors which is all I can think of, except for perhaps some fasteners .So the point of this is that driving in areas where salt is used on the roads shouldn't be a worry from a rust standpoint . Happy New Year !
Exhaust manifolds, clamps, hangers, exhaust system in general, and fasteners as you suggested? Probably fairly chunky all of that.
For sure . More aluminum used than anything.
Aluminum doesn't lose mass like steel. Also it mostly just pits or tarnishes.
Apparently it depends to a great degree on the type of alloy used . There are " marine " grades " which are more resistant than say the aluminum in your storm door. No idea what GM uses though but I suspect regardless that the degree and rate of corrosion would be less than steel.
I'n not sure how well the aluminum framework is sealed up , but road salt will cause corrosion on aluminum.
Maybe I should start to drive mine in the winter as salt isn't used here at all. Then again I'm not sure if it would like -40 degrees ambient........ ;)
That is why they make AWD SUV so you can keep the C8 for decent weather. :heavycar: ;)
Just plugged in my Tundra although it's only-32 this morning. It still only needs about two hours of juice to not to be too cranky starting. That's a battery blanket and block heater. I keep the battery tender plugged in 24/7 in the cold weather though. Got my C8 out April 15 last spring so only another 14 weeks, lol. Sim rig till then to scratch the itch . This looks amazing at 4K with HDR on an OLED . Plays amazing as well if you have the hardware to run it maxed out.....
I've worked with Fibreglass before and I would have guessed why the switch. Fibreglass is a pain. Literally. If one gets the glass particles on oneself it is itchier than hell. It's terrible to work with.
True that. When I built my first house I had a small local insulation company to do the install. He didn't use a mask or coveralls or nothing. I asked him about the fiberglass issues and all he said was " I stopped getting itchy after a few years and no one can say my lungs aren't pink"... :Ack2:
I start to scratch when I see the truck from the building supply company driving past with a load . That's why I had my garage insulated with spray foam when I finished it. Nasty crap that pink .
Ya, I used rock wool in my basement. "Safe and sound ® " in the basement ceilings and spray foam when we renovated the house.
Rock wool is much better than pink, higher R value and easier to install for sure. And no itch ! Good for hydroponics as well if you use the right type.
