Hey there,
I just received a bunch of parts from Corvette Depot which are:
1014914 Corvette Rear Sway Bar Bushings, 7/16", Rear, Polyurethane, 1963-1982
1001662 Corvette Automatic Transmission Filter Kit, Turbo Hydra-Matic350 (TH350), AC Delco, Late 1976-1981
1001011 :: KIT 3116782 :: Corvette Rear Leaf Spring Bolt Kit, Stock Length, With Urethane Cushions, 1963-1982
1001961 :: KIT 3116782 :: Corvette Trailing Arm Pivot Bolt Kit, 1963-1982
1013602 :: KIT 3116782 :: Corvette Differential Mounting Bushing, Front Polyurethane, 1963-1982
3102052 :: KIT 3116782 :: Corvette Trailing Arm Bushing Kit, Front, Without Outer Sleeves, 1963-1982
1001106 :: KIT 3116782 :: Corvette Strut Rod Kit, Adjustable Stock Type, 1963-1979
1024158 :: KIT 1032211 :: Corvette Rear Spring Mount Plate Bolts, 1978-1979
1002483 :: KIT 1032211 :: Corvette Rear Leaf Spring Mounting Plate, 1978-1979
1000996 Corvette Rear Shock Absorber Mount, Right, Lower, 1963-1982
1000997 Corvette Rear Shock Absorber Mount, Left, Lower, 1963-1982
1003790 Corvette Rear Spring, Steel Heavy Duty, 7 Leaf 2.25 Inch, 1963-1978
I have everything I need to get it back on the road but I am looking at the differential and I want it to take it down and paint it and make it look nice and also the half shafts needs some attention..
I like having a car that is clean and right now the previous owners oil sprayed it and I think it looks like s**t..
I would paint everything even the crossmember and make the car look nice..
If I remove the half shafts I need to put them back the same way since they were balanced at the factory correct?
