Question about fuel and brake lines
1978 Corvette
Hey there.
I bought and I am replacing all brand new stainless fuel and brake lines for my car.. I need to know what sizes are the fuel and brake lines in order to purchase a Handheld Tubing Straightener?
Hey Sly. I’m not sure what size they are but I’ll measure mine today and let you know.
Update - One brake line to master cylinder measures 3/16” another measures 1/4”. Porportioning valve to front brakes are 1/4”. I couldn’t measure from the porortioning valve to rear brake ‘T’ but it appears to be 3/16” and from there I believe it goes down to 1/4” to each rear caliper.
The return fuel line measures 1/4”, the supply measures 3/8”, and the gas tank vent to canister line is 1/4” as well.
Good stuff guys.
By no way take this as gospel but.....
Small block Fuel supply 5/16" OD Tube
Big Block Fuel Supply 3/8" OD Tube
Return Line 1/4" OD Tube
I have read/heard of guys putting in 3/8" OD as replacement for the supply because why not. Most after market lines tend to go to a -6AN fitting instead of just rubber hose connections. This would be the same 37deg angle and thread as JIC.
Brakes 1/4" and 3/16" OD Tube, 1/4" OD runs the long part. These would be a 45 deg double flare end (I think)
I will try to get out to the shop to verify this.
T
Brake and fuel tubing is sold as OD size. The 1/4, 3/16, are OD sizes. The handheld straightener you are considering is sold by OD as well. So if you are buying bulk 1/4 and 3/16 stainless brake lines, you will need one of each of the straighteners/benders. If you are putting new 3/8 fuel supply line in, you will also need a 3/8 straightener/bender.
Or.....in case you didn't know, you can also buy pre-bent sets if that makes your life any easier...
I bought some prebent stainless ones. They are not installed yet just laying on the frame. They are seem to be a good fit. They did come bent in half to fit in the box so there was one bend to straighten out on each but I did it by hand. Depends how much customizing there is going to be as for if it makes sense for you or not.
T
Shipping is a problem with pre bent lines. I don't think you can ever get a kink out.
All that work to get them perfect and nobody ever sees them again. Oh well you know it is correct and that is what counts.
