GO
Go chase the neighbourhood kids off of your lawn...
Get back in your cage! LOL
It contained PTFE . I remember the stuff.In the old days, I used to use a product called Slick 50 to help with reducing engine wear as the product was supposed to bond to the metal components in the engine and reduce metal on metal wear upon start up. After the engines sit they start dry with metal on metal for a couple of seconds until the oil reaches the top of the engine.
In 1992, Mobil 1 became the factory fill oil for every Corvette made. The use of 5W-30 synthetic continued for almost 3 decades until they changed to 0W-40 in the C8.
I stopped using additives in my cars once synthetic oils became available. Synthetic oil flows better and offers better protection especially in cold temperatures. It eliminated the need to use the additives. During the time I used the additives in my Camaro and older Corvettes I didn't have an engine failure. I may have gotten a bit better gas milage but I was always on it, and not overly concerned about my mpg.
Using an additive or even an oil catch can, gives GM an out if you suffer a warranty situation. If you blow up your engine your oil will be analyzed. As Mobil 1 used to market itself with zero engine wear on a micrometer after more than 100,000 miles, you are taking a chance by putting something in your engine other than the factory fill. If you still feel the need to use and additive, I would highly recommend you wait until your powertrain warranty has expired.
Absolutely. Not necessary now. They claimed at the time that it would bond to the metal. Very actively marketed. Did it work? Who knows, maybe yes maybe no but I believe it still being added to lubricants, maybe even WD 40 . Can’t recall.It was recommended for using with regular or semi-synthetic motor oils, but when I started using the fully synthetic motor oils, I felt it was redundant
and no longer necessary.
Slick 50 took out a 396 on a ‘67 Ford XLS that I owned. 48 hours after putting it in, as per the instructions, we started blowing blue smoke like a coal powered locomotive. Never again….In the old days, I used to use a product called Slick 50 to help with reducing engine wear as the product was supposed to bond to the metal components in the engine and reduce metal on metal wear upon start up. After the engines sit they start dry with metal on metal for a couple of seconds until the oil reaches the top of the engine.
Did the Ford XLS say to the Chevy 396 “ do you come here often “ ? Just curious.Slick 50 took out a 396 on a ‘67 Ford XLS that I owned. 48 hours after putting it in, as per the instructions, we started blowing blue smoke like a coal powered locomotive. Never again….
My bad. 390.Did the Ford XLS say to the Chevy 396 “ do you come here often “ ? Just curious.
I was using mine in a 5.7 litre Chevy engine. Did you find out why it took out the 390?My bad. 390.
You could always just disable the ignition (I'm sure there's a fuse that could be pulled) and let it crank 5-10 seconds to build oil pressure before firing. Personally I wouldn't put oil additives in my new, warrantied C8 (and who's to say they'll do a better job in this scenario anyway). And I also wouldn't worry about a once-a-year event. People have been winter storing cars forever and you never hear of any issues related to "dry" starts.
My C8 already seems to crank the engine longer before it activates the ignition when it's cold out.
Sorry. Didn’t mean to be to be a Richard .My bad. 390.
