Congrats on your purchase. The wait will be worth it the first day you pull it out and start going thru those 7 gears. Nice choice, Cheers!
Yes I was thinking that the splice I ended up with was because there was a paint ridgeMine is covered with one piece and it took 2 attempts to get it right. I had a good installer do it though. And yes the stuff is pre-cut out of a roll of stock to the different shapes on your car.
I found that seams will show up as more and more visible as time goes on so I insisted this one be done in 1 piece.
Yes it has a very soft inside liner Cobra.
The one available on the GM dealership website is identical to the one I got off eBay. Both in quality and price.
So if you have concerns just buy the OEM one from GM.![]()
So I'm a little confused, as I was reading the specs for the protective roof panel bag on GM's website and they provided the following description,
Packaging Specifications
Packaging Quantity1
Height7.9 in
Length26.5 in
Width16.6 in
Weight5.52lbs
UPC/GTIN00808709645535
So I guess my question is how does a panel that measures 53" x 34" fit?
My guess and hope would be that you will find “joy” once you take the bag out of the shipping box and unfold it. I wish I got a shipping box when I received mine as the accessory parts desk had it out to have me approve of it on receipt.
some good reading on water spotting on Lexan roofs from our friends at autogeekonline
@Cobra--no reason to panic --the roof is very much worth the extra care, but nice to be aware, and good practice to make it the first thing you dry after washing the car (which is never washed in direct sunlight!)
Water spot etching on Transparent, tinted roof panel for C7 Corvette coupe
Also wanted to add this year I'm trying these out to hopefully deal with hard water spotting cheaply!
CAMCO RV water filters--bought a 2 pack on Amazon based on this:
Does the carbon fibre roof panel also have a Lexan surface as well? Also wouldn't having a good wax treatment at all times help to prevent the water spots?
I'm thinking the concern would be water on the roof left to bake in the sun. I guess I better carry a shammy with me at all times so that in the event that I'm on the road and hit rain and then sunshine, at least I can take two minutes and shammy the roof to avoid this concern.......that should work. Being this is not a daily driver, my car won't be left out unattended except when going out for dinner ha ha!
Cobra--don't fret. For the most part, water spotting is due to hard water. Rain water is generally soft (or at least much softer than tap water) at least that's been my general understanding. The culprit here is your standard garden hose washing, followed by not drying, and baking in the hot sun. If you wash the car in shade and dry quickly you'll be good.
Thanks Lupo.......I'm good then! I'm one of those guys that always washes in the shade and when none is available I move the car into my garage and wash it in there......and I always shammy the water off.
Cobra![]()
Worse case scenario, dd will come over and dry it for you!![]()
Be a bit of a drive but I’m usually up for a good road trip.
I did buy a master blaster to dry the car and it works great. I don’t use it every time but it really blows the water off quick and the warm air dries the car spot free. In the sun though it actually makes it worse for spots. But on a cloudy day it is fantastic.
Allow me to paraphrase as Spence is likely busy with family time now.
If you’re getting the dual roof option (see through and solid), there is a reasonably priced storage bag for the roof you do not have on the car.
2014-2019 C7 Corvette Genuine GM Roof Panel Storage Bag 23148691 | eBay
I got mine off eBay as well. Roof fits well and nicely protected.
