need speed rated tires
Wow, Rick. Sounds like a fun car, and I need to see some pictures!
I've been out for a few days, so I apologize for not being on the ball like a millenial, haha.
As a serious answer to your question of tires, I have to ask if you are die-hard stuck with the idea of 15" wheels? There are many options available to you, and of course most of them are really expensive, but they will make a big difference in terms of performance, traction, and replacement cost. Please do consider changing your wheels to a larger diameter, and your width options will open up accordingly. 18's should still fit nicely on your car and allow you for a 9 or even 10" width, which will easily allow for 275 to 295 tires. 17's might actually be the best size to not rub too much, but they may not be the most cost-effective for tire costs any more.
If you really want to stick with 15's, I think a 295 is going to be your maximum fitment capability, but that tire is too wide to provide good traction on a 15x6 or 15x7 steel wheel. It will just balloon and smoke out a strip down the middle of the tire. There are plenty of drag radials or slicks available in 15" diameters, but you don't want to run those on the street all the time because they wear out so fast, and have not traction in any kind of inclimental weather.
I am of course making assumptions here because you haven't provided information otherwise, but I am thinking that you have stock ralleyes at a maximum of 15x7, which means that you should really be looking at a 245-275 at maximum width, and I would try to go as low on the side profile as you can endure for ride quality. I would probably have to suggest not going lower than 50-series, because those tires are half of your suspension. It might handle the corners better, but I bet your back won't.
thanks for the answer my car is 15 x8 rims I can fit a 15 x10 because I have 2inch offset trailing arms. stock rallys are 15x8 4 and quarter back space so I can do 10inch 5 and a half backspace which should take 295 50 15s but cant find any tire like that , I need a speed rated tire above s but nobody sells one, TA s are all S rated 110 mph . Because my new crate motor is going to destroy my drivetrain ? I need to stay away from sticky tires. will s rated tires be ok if I hold it down in 4th for a bit.
I went around to the tire guys around here but all they got are bfg ta tires S rated so I called summit nothing bigger than 275 S rated called cobra S rated slim pickens for 15 inch I am wondering what happens with S rated tires at speed , I have TA s on it now which before I knew better hit 147 on a nice long highway many years ago.
got pictures on my iPhone but no on this windows tower im going to pull the motor tomorrow to paint some more of the frame and neaten up my engine wiring etc .the boy s at the local car show worked hard over the winter for the may 24 show. I got to step up put some por 15 on the frame clean up my 50 year old car.. when she looks a little run down I have more fun .. the German engineering bunch think I be an easy race ????
Mickey Thompson Sportsman S/R Radial Tire - 26X8.00R15
Part number: 90000000228
rated H = 130 mph
here's a H rated Kumho :
Kumho Ecsta STX KL12 Tire - 295/50R15
Part number: 1649413
CAD Price for Kumho 1649413
$188.69
Free Shipping from Toronto, ON
Mickey Thompson ET Street Radial Tire - 26X10.50-15LT
Part number: 90000024651
CAD Price for Mickey Thompson 90000024651
$281.88
Mickey Thompson ET Street SS
26X9.50R15( 7.0 ) 6.5-8.526.29.48.382.4R229900000245283450BUY
P275/50R15
26X11.50R15
( 8.5 ) 7.5-9.526.411.110.283.0R231900000245503451BUY
P255/60R15
27X10.50R15
( 7.5 ) 7.0-9.027.310.18.885.7R231900000245523452BUY
P275/60R15
28X11.50R15
( 8.0 ) 7.5-9.528.211.19.388.6R232900000245543453BUY
P295/55R15
28X12.50R15
( 9.5 ) 8.0-10.528.011.910.687.9R234900000245553454BUY
29X15.00R15LT( 12.0 ) 10.0-13.029.014.813.091.2R242900000313413456BUY
29X18.00R15LT( 14.0 ) 14.0-16.029.017.315.891.2R246900000313433458BUY
P295/65R15
30X12.50R15
( 8.5 ) 8.0-10.530.312.010.695.1R241900000245563455BUY
31X18.00R15LT( 14.0 ) 14.0-16.031.217.715.798R250900000313423457
ET STREET® S/S
STREET TIRE FOR THE DRAG STRIP
A street tire that can be driven on the track, the ET Street S/S from Mickey Thompson is a high performance street to strip tire with radial construction, R2 compound and more; 15- to 20-inch fitments.
appreciate the advice I will get the mickey Thompson street radial for the rear thanks xfire82
...........your welcome rick , they sound like a tire that will stick and maybe let you use all those horses . good luck with project. Sorry , no info on the rack type steering . Maybe just a manual gear box will do saving any mods. My buddy's 68 SD396 Beaumont come with no ps , saved 7 hp he told me when he bought it new !! , it steers ok on the road and just a little harder parking.
well actually the car has manual steering but the header pipes are 1/4 inch away with regular big block..it melts the grease out of the box . now the tall deck engine is rubbing on it even with shimmed motor mounts. the big block cars have the motor offset to the passenger side a lot already , found that out when I went to cut hole in hood for carb when LS6 went in. with rack and pinion I can remove steering box for ever and make some 2 1/4 primary pipes which is what is needed for a 10.3 litre motor.
ahhh, I see your situation now . I know the rack / pinion will work as there was one in salvage here a couple of years ago the guy just did it then wrecked the car and the car was sold complete to high bidder. Sounds like you don't have much choice but to go that route. I'd feel more comfortable with trying to center that motor too , that's more weight than the frame was designed for and you need it to go straight when you punch it. Sounds like something a guy sees on Street Outlaws.
Here's a pic of the wrecked 81 I mentioned with the rack setup, small block car. Not much help but something to look at.
