I went with the Lloyds floormats, logo and script is sideways. I think it was worth the extra $$$
Manny will install a Corsa System (with X-pipe), an auto trans cooler, manual fan control, neoprene bushings, and an ECM tune.......
Found some nice OEM floor mats so that will spruce up the interior -- will post pics when they arrive.
What are your thoughts on the Magnaflow's Manny? I sure like the sound of them on a C3.
I went with the Corsa's on the C4 -- some of the guys were saying they had a drone problem at cruising speeds ..... Might not be an issue on your C3 Greg -- Manny will know for sure.
Yeah, might be an issue if you cruise the highway for a long time. I've found my ears ring a bit after a long drive but it sure sounds good. But then my cruise RPM's are about 2500.
Yeah my cruise rpm is about 2k .... You should listen to mine first b4 buying, and someone will have some magnaflows to compare to also.
Roll on spring .. time to go mod crazy....
an 'x' pipe should get rid of the drone. i got raptor glass packs for my 'inner teenager'
Magnaflow's for the C3's Corsa's for the C4/5 & 6 - NO DRONE ZONE
Received the red lettering for the rear of the vette today (thanks for the inspiration) as well as a few chrome caps for the engine bay. Can't wait for it to get warmer,
ERIC
Looks great! How does it mount Colin?
