Just in case you have nothing better to do ...
  • Thread starter Thread starter YFCvii
  • Start date Start date
🤔 I’ll write numbers on ping pong balls next time .... but then again someone might still have their hammer from earlier on in this thread ... 😳 😂
Three men go to stay at a motel, and the man at the desk charges them $30.00 for a room. They split the cost ten dollars each. Later the manager tells the desk man that he overcharged the men, and gives the bellboy $5.00 and tells him to give it to the men.
The bellboy, however, decides to cheat the men and pockets $2.00, giving each of the men only one dollar.
Now each man has paid $9.00 to stay in the room. 3 x $9.00 = $27.00. The bellboy has pocketed $2.00. $27.00 + $2.00 = $29.00 - so where is the missing $1.00?
:Lurk5:
It didn’t make sense to me either at first but according to the interweb (yes I cheated) this puzzle is more of a trick than a puzzle.
“The misdirection in this riddle is at the end of the description, where a bunch of unrelated totals are added together, and the listener assumes these numbers should add to 30. There is, in fact, no reason this sum should add to 30.”
then there is in fact no reason the formula should remain the same so my answers would also be valid....
OK ... time again to resurrect this thread with an aptitude check ... enjoy 😊
(I never believe the last statement on this though as it likely relates to the
percentage of those most likely to just ignore the challenge ... maybe :Shrug2: )
I can't say definitively that one or the other is incorrect ... as the pattern of addition
gets questioned and then some will argue that one must extrapolate and include
the missing statement of "4+7=32" too ... where "5+8=45"
I find I have to make some things more complicated than they are I guess ...
by finding the pattern formula of A+(BxA)=C for a "45" answer ...
which would eliminate the pattern of adding all the numbers
that one sees for a 5+8=34 result.
Cheers :Cheers2:
Cheers :Cheers2:
I agree.. There is more than one way to come up with an answer, it all depends on your approach...But, more importantly it is about the ride and not the destination....
