Hot engine, air conditioner S/D
vt65
Nov 13, 2009
881
60
Awards
3
Simcoe On
2008 4LT convert
  • 10 Years
  • You're 5
  • You're a Regular
this is a new one .... getting dash message: Hot Engine Air Cond shutdown, temp gauge sitting on the bottom, both fans running, engine coolant level is right up, no check engine light, motor doesn't seem overly hot .... anyone had this?
theboss
Nov 20, 2012
770
419
Awards
7
st-bruno, quebec, canada
1
2012 zr1 centennial
Province / State
Quebec
  • C6
  • QC
  • You're Celebrated
  • You're 5
  • You're a Regular
  • You're a Donor
I think if the pcm doesnt have temperature reading, it may start the fans in case of overheating, you still have to check for codes, a pending code might not light up the check engine light. Many GM product will not stop the fans until no more temperature related codes are still in the pcm memory. Good luck and post the results. You might try to disconnect the battery for a few minutes.
vt65
Nov 13, 2009
881
60
Awards
3
Simcoe On
2008 4LT convert
  • 10 Years
  • You're 5
  • You're a Regular
thank you
vt65
Nov 13, 2009
881
60
Awards
3
Simcoe On
2008 4LT convert
  • 10 Years
  • You're 5
  • You're a Regular
Looks like that is what happened, i disconnected the battery for 5 mins then restarted the car and took it for a 20 minute drive, all seems good so far, thanks for the suggestion.
