All free downloads.
Headlight motor gear:
www.thingiverse.com
headlight knob:
www.thingiverse.com
C4 Corvette Headlight Knob remix:
www.thingiverse.com
door vents:
www.thingiverse.com
Cup/Phone holder:
www.thingiverse.com
Delco Bose emblem:
www.thingiverse.com
1996 C4 Corvette Convertible Upper Window Support Spacer:
www.thingiverse.com
C4 Corvette Targa Top Storage Holder Cover:
www.thingiverse.com
C4 Corvette Power Seat Control Light Covers:
www.thingiverse.com
C4 Corvette hood prop rod end:
www.thingiverse.com
C4 Corvette Coolant Tank Insulator 14104598:
www.thingiverse.com
C4 Corvette Targa Top Storage Holder:
www.thingiverse.com
C4 CORVETTE DOOR DEFROST VENT:
www.thingiverse.com
C4 Corvette Seat Track Transmission shaft end:
www.thingiverse.com
Hood prop rod end for C4 Corvette:
www.thingiverse.com
C4 Corvette Rear Curtain Clips:
www.thingiverse.com
C4 Corvette Delco Radio Bracket:
www.thingiverse.com
C4 Corvette Offset Cup Holder Adapter:
www.thingiverse.com
GM Saturn Pontiac Corvette pop up headlight motor gear by Usagoal
This is the worm gear for the pop up/flip up headlight motor on my 96 saturn. It's common for these gears to strip their teeth rendering the headlight motor unusable. Replacement gears are available in brass, aluminum and plastic (i've heard the aftermarket plastic gears also strip out fairly...
headlight knob:
C4 Corvette Headlight Knob by Cellularr
I made this for my C4 Vette as I was tired of the OEM one falling off due to loose fitting. This part requires a little force to put on, but it is all good as the fit is tight. This surely beats spending around $20 online for an OEM one. Happy printing and let me know how it goes!
C4 Corvette Headlight Knob remix by gamekiller7
https://www.thingiverse.com/thing:4441076 presented a thumb screw to replace the wing nut on the front-left corner of the BIBO bed. It is too wide for the other two positions.I have created a smaller version to fit the right-front corner and the back-center.A M3-.50 nut is required.
door vents:
Corvette C4 side window air vent (updated) by blue-v
Now in 1:1 original size. Sorry for wrong scaled thing! This is a replacement part of the Chevrolet Corvette C4 (1983-1996) air outlet for the side windows.These parts are made from plastic and tend to break when they get older.So did mine on my '88 convertible.As I found no original or after...
Cup/Phone holder:
C4 Corvette Phone CupHolder by Chbtransam
HelloI was looking to hold my iPhone 8 Plus while driving my 1984 C4 Corvette.I have designed this cupholder which fit exactly in the C4 Corvette cupholder.The design was made in Fusion360.For print process i've made a "filament change" to make the Corvette brand and Logo visible. This up to you...
Delco Bose emblem:
C4 Corvette Delco Bose Radio Emblem by mpk944
Delco Radio Emblem for C4 corvette radios. Made this for my radio after adding Bluetooth. Turns out its too small to print on my machine but may work with better programming.
1996 C4 Corvette Convertible Upper Window Support Spacer by gdl2165
I had the convertible top replaced on my 1996 C4 Corvette and it ended up just a little bit low, causing it to slip down off the upper support pads. I designed this upper window support spacer, just a little bit wider than OE and it solved my problem.
C4 Corvette Targa Top Storage Holder Cover by sunsetvette
I just completed the Targa Top Storage mount Cover. It goes along with the mount that I drew up. https://www.thingiverse.com/thing:4741298 I printed it out of TPU because it will take the heat and if you smack it, it's not going to crack or break.
C4 Corvette Power Seat Control Light Covers by gvlgvl
Check out C4 Corvette Power Seat Control Light Covers by gvlgvl on Thingiverse.
C4 Corvette hood prop rod end by jayjones
I've printed this is PLA and resin and they both work fine, although it seems like the resin is more heat resistant
C4 Corvette Coolant Tank Insulator 14104598 by belairbrian
This goes between the coolant tank and bracket. Printed in TPU for flexibility
C4 Corvette Targa Top Storage Holder by sunsetvette
My garage queen 1990 Corvette was needing a new top, after getting stuck by Ecklers I sent my original top off to Astro Tops to be rebuilt. They were a great company to work with and the top is better than new (Feb 2020). In the spring when the roads were clear of gravel I took her out, it was...
C4 CORVETTE DOOR DEFROST VENT by mcmxgta
-Redesign of the door defrost vents for an early C4 Corvette.-Blank area in center open for customization if desired.-Should fit years 84-89.
C4 Corvette Seat Track Transmission shaft end by slvrshrk
I designed these as direct replacements for the nylon shaft ends found in the Corvette C4 power seat transmission. These commonly break from people getting in and out of the seats. When I looked further, I saw that by extending the length of the cap it would rest against the metal case and...
Hood prop rod end for C4 Corvette by jayjones
I printed in PLA @ 200c nozzle and 60c bed
C4 Corvette Rear Curtain Clips by sunsetvette
Replacement clips that hold the rear deck cover for 84-96 corvette coupes.
C4 Corvette Delco Radio Bracket by mpk944
This is the bracket that holds the radio into the center console (1 per side).
C4 Corvette Offset Cup Holder Adapter by PaulVette
Coffee Cups were smaller back in the 90s. None of our newer travel cups fit in my cup holders.
