All free downloads.
Headlight motor gear:
headlight knob:
C4 Corvette Headlight Knob remix:
door vents:
Cup/Phone holder:
Delco Bose emblem:
1996 C4 Corvette Convertible Upper Window Support Spacer:
C4 Corvette Targa Top Storage Holder Cover:
C4 Corvette Power Seat Control Light Covers:
C4 Corvette hood prop rod end:
C4 Corvette Coolant Tank Insulator 14104598:
C4 Corvette Targa Top Storage Holder:
C4 CORVETTE DOOR DEFROST VENT:
C4 Corvette Seat Track Transmission shaft end:
Hood prop rod end for C4 Corvette:
C4 Corvette Rear Curtain Clips:
C4 Corvette Delco Radio Bracket:
C4 Corvette Offset Cup Holder Adapter:
GM Saturn Pontiac Corvette pop up headlight motor gear by Usagoal
This is the worm gear for the pop up/flip up headlight motor on my 96 saturn. It's common for these gears to strip their teeth rendering the headlight motor unusable. Replacement gears are available in brass, aluminum and plastic (i've heard the aftermarket plastic gears also strip out fairly...
www.thingiverse.com
headlight knob:
C4 Corvette Headlight Knob by Cellularr
I made this for my C4 Vette as I was tired of the OEM one falling off due to loose fitting. This part requires a little force to put on, but it is all good as the fit is tight. This surely beats spending around $20 online for an OEM one. Happy printing and let me know how it goes!
www.thingiverse.com
C4 Corvette Headlight Knob remix by gamekiller7
https://www.thingiverse.com/thing:4441076 presented a thumb screw to replace the wing nut on the front-left corner of the BIBO bed. It is too wide for the other two positions. I have created a smaller version to fit the right-front corner and the back-center. A M3-.50 nut is required.
www.thingiverse.com
door vents:
Corvette C4 side window air vent (updated) by blue-v
Now in 1:1 original size. Sorry for wrong scaled thing! This is a replacement part of the Chevrolet Corvette C4 (1983-1996) air outlet for the side windows. These parts are made from plastic and tend to break when they get older. So did mine on my '88 convertible. As I found no original or...
www.thingiverse.com
Cup/Phone holder:
C4 Corvette Phone CupHolder by Chbtransam
Hello I was looking to hold my iPhone 8 Plus while driving my 1984 C4 Corvette. I have designed this cupholder which fit exactly in the C4 Corvette cupholder. The design was made in Fusion360. For print process i've made a "filament change" to make the Corvette brand and Logo visible. This up to...
www.thingiverse.com
Delco Bose emblem:
C4 Corvette Delco Bose Radio Emblem by mpk944
Delco Radio Emblem for C4 corvette radios. Made this for my radio after adding Bluetooth. Turns out its too small to print on my machine but may work with better programming.
www.thingiverse.com
1996 C4 Corvette Convertible Upper Window Support Spacer by gdl2165
I had the convertible top replaced on my 1996 C4 Corvette and it ended up just a little bit low, causing it to slip down off the upper support pads. I designed this upper window support spacer, just a little bit wider than OE and it solved my problem.
www.thingiverse.com
C4 Corvette Targa Top Storage Holder Cover by sunsetvette
I just completed the Targa Top Storage mount Cover. It goes along with the mount that I drew up. https://www.thingiverse.com/thing:4741298 I printed it out of TPU because it will take the heat and if you smack it, it's not going to crack or break.
www.thingiverse.com
C4 Corvette Power Seat Control Light Covers by gvlgvl
Download files and build them with your 3D printer, laser cutter, or CNC.
www.thingiverse.com
C4 Corvette hood prop rod end by jayjones
I've printed this is PLA and resin and they both work fine, although it seems like the resin is more heat resistant
www.thingiverse.com
C4 Corvette Coolant Tank Insulator 14104598 by belairbrian
This goes between the coolant tank and bracket. Printed in TPU for flexibility
www.thingiverse.com
C4 Corvette Targa Top Storage Holder by sunsetvette
My garage queen 1990 Corvette was needing a new top, after getting stuck by Ecklers I sent my original top off to Astro Tops to be rebuilt. They were a great company to work with and the top is better than new (Feb 2020). In the spring when the roads were clear of gravel I took her out, it was...
www.thingiverse.com
C4 CORVETTE DOOR DEFROST VENT by mcmxgta
-Redesign of the door defrost vents for an early C4 Corvette. -Blank area in center open for customization if desired. -Should fit years 84-89.
www.thingiverse.com
C4 Corvette Seat Track Transmission shaft end by slvrshrk
I designed these as direct replacements for the nylon shaft ends found in the Corvette C4 power seat transmission. These commonly break from people getting in and out of the seats. When I looked further, I saw that by extending the length of the cap it would rest against the metal case and...
www.thingiverse.com
Hood prop rod end for C4 Corvette by jayjones
I printed in PLA @ 200c nozzle and 60c bed
www.thingiverse.com
C4 Corvette Rear Curtain Clips by sunsetvette
Replacement clips that hold the rear deck cover for 84-96 corvette coupes.
www.thingiverse.com
C4 Corvette Delco Radio Bracket by mpk944
This is the bracket that holds the radio into the center console (1 per side).
www.thingiverse.com
C4 Corvette Offset Cup Holder Adapter by PaulVette
Coffee Cups were smaller back in the 90s. None of our newer travel cups fit in my cup holders.
www.thingiverse.com
