Well the wheel has finally arrived and I got to say socal garage works does an amazing job on there wheels, detail and workmanship is amazing guys!
was well worth the wait !!!
as of right now I'm having a bit of compatibility issues with the led screen in the wheel... both power issues and pairing with obd module issues.
Greg at socal has been great and helping me trouble shoot this issue and trying to rectify it! it turns out it may not be compatible with the c5 but that is not ruled out as of yet. But if so they showed how well their customer services is and offered to take the wheel back remove the screen portion and finish it in carbon on the top instead and to me that goes a long way!
So just to give you guys and idea of what is going on the wheel wires standard postive and negative connection. the wheel will power up upon starting of car then it powers down if i hold in the two buttons it powers back up and starts looking for the obd2 module that plugs in under dash. I then press the pair button on the module and the wheel will display matching success so now it is connected to the obd2
now the wheel should display info like rpm gas... oil... etc.
mine shows all zeros and well not pick up the data. if i stop scrolling through the menu the wheel will then turn off once again causing me to have to hold the buttons and repair it all over again.
so tested this by placing the wheel on the seat of my 2014 sierra hooked to a battery. plugged the module in under dash and all the same issues so that eliminated any issues with the C5.
so that being said Greg agrees there is most likely an issue with the screen and module but the supplier of them parts say its not compatible or not hooked up properly.
so I will keep yall updated if we end up getting this working cause it is a very cool option!! but if not socal is good enough to fix the issue and provide me with a super cool wheel for my ride
check them out guys yas wont be disappointed the wheels are amazing!
Google Socal Garage Works
