Cabin filter replacement - DIY question
Very easy to do...Thanks for reminding me..will probably change mine this week :)...Its in the owners manual
There is an access door directly above the battery with 3 spring retainers.
Open the door and slide the filter out towards the front.
NOTE: There is a FLOW arrow on the filter, so it is installed the correct way
I find those cabin filters don't work so well when you cruise with the windows down.:rofl:
That, and every time you open your doors, stuff can blow in. It would just be nice to have a filter for those times you can see it's dusty or have to drive through a dusty area, then you can at least seal up the car.
