M
MADDOX
How much boost is to much for a stock LS2 ?
How much rwhp can it make on that boost ?
Just thinking!!!!
Thanks
Just thinking!!!!
Just thinking!!!!Thanks
Thanks for the info
Do you stock pullys and belts for vortech charger?
What needs to be done to the bottom end to beef it up? How much would that cost?Do you have to pull the motor to beef it up or can remove oil pan to do the work?After the bottom end is done how much boost can you use?
Do you tune or do you have someone that does it? What the cost for a tune
Do you have a dyno and the cost to do some pulls?
Do you stock meth kits and how much to install .Thanks again
Good to know .Now whats you'r input on just running 6lbs of boost and spray'in 150 shot does anything need to be done to the car if I go this way. Thanks
My gole is to make 600 to 700 to the ground
Whats the differents in HP between 6lbs and 8lbs of boost ?
I was thinking the the motor would last longer at 6lbs and just spray it when I need it.
So whats the next weakest link trans or rearend? Whats the cost on that?
Thanks for your time
Manny whats the cost with out install
Carbin Fiber driveshaft ? LG - $1750 / Pfadt $2500 tax incl
Twin clutch ? RPS Twin $3050 tax incl
Trans and Dif Brace? DTE Dif / Trans brace $530 tax incl
Trans Mounts? Pfadt Trans mount $395 tax incl
Underdrive pully? If you are going to boost , you will need either a stock size ATI , not an underdrive pulley as it will lower the boost . Ati stock size pulley $550 tax incl
Thanks
