Yes as you can see in C7Jake picture there are 4 little 3/16 holes drilled to mount the licence plate, 1 in each corner.
Thank you for your reply. Is that bracket different than the Aero Panel? According to the description, that one doesn't require any holes drilled:
For provinces that require front licence plates, this Carbon Flash Front Aero Panel Frame Kit fastens to the front fascia of your Corvette Stingray without drilling any holes in the bodywork. Front Aero Panel Frame Kit in Carbon Flash
The Aero Panel is the one that came with your car and does not require any drilling to mount. What Jake did was trim the aero panel so that it was frameless in appearance
