Active Handling Icon
Tim C.
Active Member
You're 5 C6 You're a Regular
Corvette 2006 Coupe
'Service engine soon" Locked in Park. "Active Handling icon kept coming and going..finally GM found the code and replaced the brake pedal switch and module...good to go
Anytime your car is out of commission and then you hear the words "its good to go" the day just got a whole lot better. Sounds like it was a simple fix!
Happened again yesterday 'service active handling icon' came on . back at dealer..bummer
Damn Tim C........ you went from "the day just got a whole lot better" to WTF..... hopefully its just a matter of a simple electrical Gremlin and they get it right 2nd time around. Good luck.
Recalibrated brake switch circuit...no charge . good to go again..thks
Something you can spend some time on is cleaning all the grounds for the car. I think there are five major ones. Do you have a shop manual for the car? These cars are just to sensitive to voltage losses, worth a look to clean up any sketchy looking connections.
Frustrating, we have all had our electrical issues with these cars.
Would you believe last night at 8pm happened again 'actvice handling' icon came on again. Drove right to Myers Orleans and left it..omg
With the service active handling warning amongst others, it came down to the steering wheel angle sensor. No more problems a month or so later. With Active Handling, everything is related and the computer goes crazy trying to figure things out when one part acts up. All this needless complication is my biggest worry in owning one of these cars. Electric door opener buttons then mechanical duplication in case the battery goes dead. Waste of money. I'm getting older but I think that I can still open a door without help.
