The issue is after driving at highway speeds for 15 - 20 mins I start to hear a knock from the motor. The car will kick and buck like it is not getting fuel or spark and a loud knocking nose form the engine. It is worse under load. The engine will keep running and if I slow down or let it cool off it will come back to normal. I can drive around the city all day and not have an issue. I have replaced the fuel pump and rod as well as checked the fuel sending unit and all filters and lines and there seems to be no issue there. I have also tried a distributor coil and module and again no change. The problem seems to be worse after a short run on the highway and then trying to accelerate after getting off the highway. I was told it could be a carbon build up so going to try a seafoam cleaning to see if that helps. Any other suggestions?????????
