I have a 2023 C-8 Z51 with 600 km and a terrible brake squeel at 1 - 5 KPH. It is so loud it is Embarrassing to pull up to any intersection. It has done this since I drove it home from the dealership. I read some of the forums and have tried to Bed the Brakes 10 to 100 KMPH done 12 times in a row. This actually did work but for only 200 KM. I found another video which indicated there was a Service Bulletin on this problem. The fix involves removing the front pads and placing a bead of Permetex Copper on the leading edges of the Pad as well as on the back where the piston touches. I have an appointment at the dealership May 16 and I will keep all posted as to whether this is a long term fix. For a $100,000 plus car the brakes should not squeel this bad even though the brakes were designed for track use.
Would appreciate any feed back from any of you that have had this GM fix.
