2000 C5 MN6 transmission rebuild
AhmedA
I'm New Here
C5
I've been having issues for a while.. first the clutch pedla gets stuck so i know the mater cylidner has to be replaced... second... the third and fourth gear are hard to get into, shifting overall in each gear (1st, reverse even) takes effort... but the third and fourth, well now third gets stuck too so I have to juggle it out.
I have been reading and that may mean a rebuild... plus a clutch change... I am aware the Mn6 has forks and keys that are garbage and at that point probably a good idea to change synchros for 3-4....
What do we have locally for rebuilds?
Either i guess... I am replacing the master cylinder with the tick aftermarket setup... and im getting mgw shifter with lowerbox hopefully these will resolve all my shifting issues... however 3rd and 4th may be synchro, fork, etc... it makes me one sad panda, but in case it comes down to that... rebuilding with bille shift forks and bronze guides is a must... i am not sure who could and for how much...... or if buying a mn6 would be better off for now...
