I recently had the clutch fluid replaced by a qualified professional. I have 31, 000 Km
on the car and I'm having trouble getting stick shift into 1st even when the car is at a stop. Any ideas what the issue is and how it may be resolved??
If I come to a dead stop, shift into 2nd, then back up into 1st it goes in without grinding but if I try to go directly into 1st it will grind! Every other gear shift is totally smooth and fine. No accidents, no bad shifts etc that may have caused damage to syncro etc. . Just started happening about 1 month ago.
Thank you
Thank you
