Z06 Rear Wheel Spacer
Just got these 2M rear wheel spacers for the rear oem wheels. 20mm.
Typical with the C8s. Non of the oem variant wheels shits flush with the fender.
I will put them on the car this weekend and post some pic of it.
I wonder when will GM get the wheel offsets right on these cars.... :rolleyes: I am using stocks as winter wheels and the offset is horrible. At least they throw less rocks to the side because of the offsets.
Just for this concern. I made my own neoprene mud guard extension to keep some of the debris from kicking up on to rocker panel and the rear diffuser.
Yeah rock protection is a much on these cars. I have mud guard on the front and PPF on the entire lower 1/3 of the car.
I may do that as well ppf the lower part of the rocker. Will see.
I had also replaced the stock side skirt with the full length one. That should help as well along with the wider mud guards.
Are there any options for wheel offset to make the car look better without spacers?
I have been thinking of getting summer rims for summer tires and it would be nice to get a better looking offset.
Any aftermarket rims will have correct offset. If you do need wheel spacer, I have a new set of 4, 20mm offset for the Stingray. Half price at $70.
Naw, I don't want spacers. I was hoping there would be options for wheel offsets.
Btw, I had mistakenly bought an extra set. Post in the classified section.
Great option to get those wheels to sit flush .....
On Paragons website ... the installation video shows that you have to install the spacers and grind the original lug nutz ..... ouch !
Pulling out the Milwaukee big 6 and applying it to the Corvette makes me cringe ... and I'm guessing if you wanted to remove the spacers and go back to stock .... it would be a problem ?
Good luck and please post some pics ....
Young Beautiful Woman Wearing Bikini with Sad Expression Covering Face with  Hands while Crying Stock Image - Image of stress, emotion: 214453143
Fyi, you must have been referring to their 15mm spacers?
Product Update:
You no longer need to trim the wheel studs as shown in the video with our old designed 15mm wheel spacers.
Mine were from 2M. No grinding or anything?
