- Thread starter
- #41
Great for the driver. The passenger not so much. Or so I have been told lol...
Get their own car? lol..Great for the driver. The passenger not so much. Or so I have been told lol...
Me neither. I avoid 93 0r 94 octane. Higher octane is achieved by adding more ethanol and does not equal higher performance or less buildup in an engine. Our cars don't require that high an octane level and I'm not an ethanol fan for anything. Unfortunately it's getting harder and harder to find fuel without ethanol.I've never used 93 or 94.
Unfortunately the manual says this.Me neither. I avoid 93 0r 94 octane. Higher octane is achieved by adding more ethanol and does not equal higher performance or less buildup in an engine. Our cars don't require that high an octane level and I'm not an ethanol fan for anything. Unfortunately it's getting harder and harder to find fuel without ethanol.
From what I’ve found doing a bit of research, at least with Shell gasoline which I use, both their 91 and 93 octane gas have the same 10% ethanol content as required by law. Both are TopTier . Blame the eco radicals for that. Among other hairbrained regulations……for what it’s worth there does seem to be some difference between the recommendations for the LT1 vs the LT2 ….Me neither. I avoid 93 0r 94 octane. Higher octane is achieved by adding more ethanol and does not equal higher performance or less buildup in an engine. Our cars don't require that high an octane level and I'm not an ethanol fan for anything. Unfortunately it's getting harder and harder to find fuel without ethanol.
The recommended octane rating for the engine in the C7 Corvette, specifically the LT1 6.2L engine (Stingray), is 93 octane for optimal performance and fuel economy. While the engine can run on lower octane fuel such as 87 or 91 in emergencies or lower altitude areas, using less than 93 octane may lead to reduced acceleration, fuel economy, and potential engine knocking. Prolonged use of fuel below 93 octane could cause engine damage and void warranty coverage. The higher 93 octane rating is not strictly required but strongly recommended by Chevrolet for best performance and engine protection.
For supercharged LT4 (Z06) and LT5 (ZR1) engines, 93 octane is required, with 100 octane or higher recommended under track conditions or high temperatures.
In summary:
• C7 Stingray (LT1): 93 octane recommended, 87 octane can be used temporarily but not ideal.
• C7 Z06 (LT4) and ZR1 (LT5): 93 octane required, higher octane recommended for high-performance conditions.
Using top-tier fuel brands also helps ensure fuel quality, regardless of octane.
The recommended octane rating for the C8 Corvette is 91 or higher, with 93 octane being preferred for optimal performance. The owner’s manual specifies 91 octane as the minimum required, but using 93 octane can enhance performance and engine protection. Using lower octane fuel than 91 is generally not advised except in emergencies and may cause reduced performance due to engine timing adjustments that the ECM makes to protect the engine.
In summary:
• Minimum recommended octane: 91
• Preferred octane for best performance: 93 or higher
This matches Chevrolet’s guidance and owner experiences indicating the C8 runs well and safely on premium 91 or above octane fuel.
Hmmm….just trying to help.All this information would be great in a Tech Thread, not in a thread where I'm trying to gain some positive attention instead of the hate that I usually draw lol...
At least you can take a joke. Good sign , lol.After reading that, I feel like I should just jump already lol...
I can give you some pointers on rolling a car.Ok, new exit plan. A week Saturday I'm going to drive up to the Ux, roll my car in front of a "Mods" house and have it burst into flames. When people drive by they will say "Oh, that must be where Murray's Car-B-Q is"...
I did a google street view search of your address....It's only a 4 foot drop....I have one leg back inside the window frame now...
We could all chip in on a ladder ………I did a google street view search of your address....It's only a 4 foot drop....
