Question Water accumulation HTC rear window?
Concours
You're 5 C8
Corvette 2021 Conver
Did somebody find a practical solution for rear window water accumulation on HTC C8 ? It is impossible for me to change my way of parking.
Is there an issue with it leaking into the car? I don't see an issue otherwise. Are you worried about it getting dirty when you drive off? You park outside you are going to get this.
Try using a leaf blower to remove the water after washing your car.
The proble it is not washing the car…….it is the rain.
Reviving an old thread here but I recently discovered a feature that I think others may find interesting and FWIW water has accumulated on my '21 since day 1. It's just something I have learned to deal with.
While spraying mine down at a self wash stall the other day, the horn started beeping and the lights flashing just as they would if I had pressed the panic button. I immediately knew I hadn't pressed the panic button as it was inside my bag of chamois that were 10 feet away. That's when I noticed that I had unknowingly left the rear window down approximately an inch. So I guess there is some sort of sensor(s) in the cabin to alert blockheads like me in such instances.
Fortunately the alert occurred fairly quickly too as the cabin was somewhat wet but nothing that a chamois or two couldn't handle. Nice feature Chevy
Mavrik
