Velocity Yellow Paint. Where to buy?
Looking to purchase three stage (Tint) Velocity Yellow paint for a 2007 Z06. Any suggestions. Much appreciated.
Hi and welcome to CCF ! This isn't something I'm at all familiar with but did find this using Perplexity AI . The results have footnotes ( links ) to where the info was sourced from but don't show up with a copy and paste. If you search with Perplexity you will see them which will help as they do show sources. Hope this helps.
Velocity Yellow Tintcoat on the 2007 Corvette Z06.���Code Confirmation ,The GM factory paint code is 45U (or 45), with equivalents WA300N, 300N, and G8A specifically for this three-stage tintcoat used on 2005-2013 C6 Corvettes, including the Z06.��� Multiple automotive paint suppliers confirm WA300N matches the 2007 Z06's Velocity Yellow exactly, as it's the DuPont/Axalta industry standard for OEM touch-up and refinish.��Cross-References , GM code: 45U/45 �Touch-up codes: WA300N (primary), 300N (alternate), G8A ��
Verify your vehicle's code on the driver's door jamb or glovebox sticker to ensure an exact match before purchase.�
Or go to your local Sherwin Williams Auto Paint store and they can put a touch up size or any size for you including in aerosol can. Go to a art and craft store and buy yourself a fine quality paint brush to use for fine touch up. To top it off, put a coat of 2 stage clear coat for best protection.
Hi, thanks for sharing this info — really helpful 👍
Have you already checked the paint code on the car itself (door jamb or glove box sticker) to confirm it matches 45U / WA300N?
