Universal remote
Joined
Jul 3, 2019
Ok after many attempts to get the garage door opener in the visor to work I am seeking a solution or advice to make it happen.
2007 US car [imported 2011] 3LT with 3 buttons and led's in visor. I have tried the directions in the owners manual but still no joy.
What am I missing? All sarcasm will be graded Thanks
As Bob said.......small button on the back of the opener.
Have the car parked as close to the door without getting it smashed.
Hold visor button 1 & 3 for a few seconds to clear any previous settings.
Press small button on the garage door opener.
Run to the car (you have roughly 30 seconds) and press your desired visor button and hold it until the light on your garage door opener blinks.
That should work.
With mine I followed the instructions in the manual but also have to press a button on the opener itself . I have a Liftmaster and it is called the learn button . It says to press it and with in 30 seconds press the remote you want to add . I did this while pressing the 1 button on the visor and the already programmed remote at the same time . Good luck
With mine ... all the above with Corvette Outside and facing the door opener (for the initial setup).
