Ok so... I am just back from a rather extended trip of the Eastern US and Canada in the Z and will post another thread with some amazing piks shortly. I encountered two issues on the trip which I thought I might throw by the experts here though, in hopes of getting a better idea of the problem and fix.
1. Center Console Display Doesn't Return - I can always get it to lower on the first push of the button but, about half way through the trip, it became rather cantankerous and now I have to press it 3 times for a return. The first time it comes up just partially enough to see the move, second press no movement at all and then the third puts it back all the way. I am certain nothing got caught in there and it is an issue with the electronics/computer as it is the same every time to return...three presses. Thoughts???
2. Some Strange Rattle or Echo Under Front End - This is most noticeable when cruising at around 55-60 and is definitely up front somewhere. It seems to be coming from the area of my feet. It is some type of a rattle or echo and is completely random. It is like something might be lose in the drive train or front somewhere. It does not affect mileage or driveability whatsoever and is only noticeable when the music is off and cruising at 55-60 if you listen carefully but it is there.
Thanks in advance gang. I should be one to complain though...lol. We are above 23000 miles in under a year's driving and have traveled most of the US and Canada in search of some amazing enthusiast driving roads.
