Transmission oil name
Hi Group I need to know what’s the company name for oil transmission. I need to change it. Because I have trouble with my car it automatic 2016 stingray z51. Thanks
Hi and welcome to CCF ! I took a look and found this. Bear in mind it’s an AI search result..
The 2016 Corvette Stingray Z51 uses an 8-speed automatic transmission (8L90). For the transmission fluid, the recommended type is a synthetic automatic transmission fluid, with the Formula One Synthetic LV ATF HP often cited as a preferred option for this transmission. The fluid capacity for the Z51 package transmission is about 9.8 quarts.
Regarding the manufacturer, the original equipment manufacturer (OEM) transmission fluid typically recommended is a GM-specified synthetic ATF. Some users and service guides suggest high-quality synthetic options like Formula One Synthetic LV ATF HP or similar high-performance synthetic ATFs that meet the GM requirements.
For the transmission fluid filter, it is normally replaced along with the fluid during service to ensure optimal performance.
In summary:
• Transmission oil type: Synthetic automatic transmission fluid (ATF), such as Formula One Synthetic LV ATF HP.
• Fluid capacity: Approximately 9.8 quarts.
• Manufacturer: GM OEM or high-quality synthetic brands meeting GM specs.
Fluid Capacity: Approximately 9.8 quarts total, though draining the pan yields about 6.5 quarts.
• Temperature Requirements for Filling: Fluid level should be checked and filled within a temperature range of 95 to 113 degrees Fahrenheit, as transmission fluid expands with heat.
• Torque Specs for Transmission Pan Bolts: 89 inch-pounds.
• Additional Notes: The transmission fluid fill process involves filling through the fill plug and cycling the gears to ensure proper fluid level. The transmission filter should be lubricated with transmission fluid before installation.
This fluid type and procedures are intended to ensure proper shifting performance and durability of the 8-speed automatic transmission equipped on the Z51 package Corvette.
This looks to be the right one although double check of course. Seems like a pretty fair price.
In summary:
Thanks
