Approx. how many Km's are people getting out of the PSS tires.
Thanks
Thanks
I'm only at 15k. I drive and corner agressively but not much for spinning rubber off. I see no appreciable wear on the PSS on mine at all. I had my front camber and caster reset at the dealer when new though too. Camber especially, set for performance/track will scuff the inside edge of the fronts right to nothing. Found this out with my C6. At 20k, developed this little vibration... thought it was a balance issue and they found my inside edge of the fronts were right down to the cords. I was lucky as I was leaving in two days later for a Wyoming cruise. Front camber should be as close to 0 degrees as you can get... caster around 7 degrees... Or at least that's worked for me. Guesssing the Z06 would likely be the same but if you are inclined to check, a reputable dealer will check and adjust camber for free. At least mine did) After that, the burning off of rubber will be under no one's control but yours... ....
17,000 Km's on my Michelin Pilot SS ZP run flats that were installed in 2015. Tread wear is negligible but I don't do burnouts only some occasional spirited driving on twisty winding roads.Approx. how many Km's are people getting out of the PSS tires.
Thanks
The big factor is driving habits. Some will be pulling them due to aging out and others due to burning them out. Also the faster you drive the more wear you’ll experience. Michelin says 50000km/30000 miles. Most will not see that. Spirited drivers won’t see much wear at 10-15000 km as stated above. They are a decent compound but nowhere near as soft as the more track focused tires out there. The cups for instance would be dead at 10000 km (or long before) of spirited street driving. Many are toast at 5000 lol. You will find the pss’s hold up/ wear well for street driving.
How many Km's do you have on your car.They aren't cheap but they will last fairly well all considered. Unless you are intentionally putting on big smoke shows on the regular that is. Then you are in effect burning money : )
They will handle quite a bit of spirited high speed driving and hard launches with wheel spin though. They are never going to be cheap to replace but buying from the right place will save you a sizable chunk of change.
Thanks for the info.
They seem like they will be pricey to replace.
Rob
This morning I was at my local tire dealer Kal - Tire in BC getting my snow tires removed and a flat fixed on my daily driver. Out of curiosity I asked for a quote to have a new set of Michelin Pilot 4S for my 2007 Corvette. The 4S is the new tire that replaces the Pilot Super Sport although they do not come in a run flat ZP tire. The total quote for the tires, mounting, balancing, enviro fees and taxes came to $1,980.83. The front tires 245/40ZR18 were $342.29 ea. and the rear 285/35R19 are $502.01 ea,Thanks for the info.
Rob
This morning I was at my local tire dealer Kal - Tire in BC getting my snow tires removed and a flat fixed on my daily driver. Out of curiosity I asked for a quote to have a new set of Michelin Pilot 4S in my 2007 Corvette. The 4S is the new tire that replaces the Pilot Super Sport. The total quote for the tires, mounting, balancing, enviro fees and taxes came to $1,980.83. The front tires 245/40ZR18 were $342.29 ea. and the rear 285/35R19 are $502.01 ea,
I used these tires for my Shelby last year . Pretty amazing tire compared to the stocker that were on it , decent price as wellThis morning I was at my local tire dealer Kal - Tire in BC getting my snow tires removed and a flat fixed on my daily driver. Out of curiosity I asked for a quote to have a new set of Michelin Pilot 4S for my 2007 Corvette. The 4S is the new tire that replaces the Pilot Super Sport although they do not come in a run flat ZP tire. The total quote for the tires, mounting, balancing, enviro fees and taxes came to $1,980.83. The front tires 245/40ZR18 were $342.29 ea. and the rear 285/35R19 are $502.01 ea,
I got 19,000 kms on the fronts and, a pretty impressive 32,000 kms out of the rear tires Michelin Pilot SS ZP run flats . Had the rears replaced last year , its a 2015 Z06 . I had the caster/camber adjusted when the new front tires were installed just to get some added life out of them .Approx. how many Km's are people getting out of the PSS tires.
Thanks
Considering the extra horsepower you’re running, 32000 on the rears is excellent
Im reading on the "other" forum there are many owners reporting rim crack issues saying its not due to driving into a pothole or rough roads...in particular the gs rims as they are thought to have thinner rim spokes vs the z06.... No personal experience.. this guy had all four corners bent...…….wowHas anyone experienced a bent or cracked rim on their C7's ?
Not one...but 4 bent wheels on my '19 GS - CorvetteForum - Chevrolet Corvette Forum Discussion
C7 General Discussion - Not one...but 4 bent wheels on my '19 GS - Sorry Tadge... calling BS. This is my 3rd C7, the last being 16' Z51 package... have I moved ? no.... is there excess construction or roads that look worse than the Ho Chi Minh trail that I drive on ? Nope, Have all of my...www.corvetteforum.com
Not making judgement or recommendation but we have a lot of C7 owners here and very few cracked rims. That being said, and to my recall, all of them admitted to hitting nasty a$$ potholes.
