Tire pressures
A 700km day cruise from just South of Edmonton, thru the Edmonton area to St.Paul and back on Canada Day
had outside temps in the high 30's and tire pressures on my C7 reached into the 260's. With my non-magride suspension,
yes it can be a bit rough depending on the condition of the pavement.
Actually, 210 KPA is 30.45 psi, 244 KPA is 35.39 psi, so 5 psi increase. 1psi is about 7 kpa, still nothing to worry about but still surprising that they will go up 15%.
Nitrogen might be a good solution as it isn't affected buy temp.
