LS3 West Coast Cylinder Heads Swap - Head Games
Redline's Cam-Only '09 C6 Makes Over 518 RWHP With WCCH CNC LS3 Heads
April, 2009
By Scott Parker
Photography by Scott Parker
It has been dubbed by many as a mini-LS7, and for good reason. Bone stock, our '09 C6 tester made a whopping 406 rwhp
on Redline Motorsports' Dyno Dynamics rollers. With a big cam, Kooks 1 7/8-inch long tube headers, Borla exhaust, VaraRam
cold air intake and custom tune, output jumped to 483 rwhp, not to mention well over 400 lb-ft of torque.
We couldn't help but wonder what the LS3 would be capable of with a good set of CNC-ported stock heads.
Thankfully West Coast Cylinder Heads was more than happy to comply with our wishes, as they have been running a well
planned CNC program on the identical L92 heads for over a year now. With these bad boys we were confident Redline tech
Jon Bettini's C6 would hit 500 ponies.
Follow along as GMHTP makes another trip up to Redline's pristine Schenectady, NY shop.
With the LS3 all buttoned up, the C6 went back on the Dyno Dynamics rollers. Despite the size of the runners, the gains were
all across the board. It seemed to take a few pulls for the PCM to "learn," but eventually Howard tweaked the tune using EFILive
to get rid of some knock at the top end (most likely from the sizable bump in compression) and we had an LS7-shredding 518 hp
and 452 lb-ft of torque at the wheels. That's a gain of 36 hp and 30 lb-ft of torque. Not too shabby considering how good the
heads are from the factory, and that this is only a stock cube motor.
