Can someone help me figure out how to program the garage door opener that is in the sunviser of my 06 corvette ? I have read the manual and tried what it said, but can't get it to work. Thanks Paul
Paul, if you still have the manual for the garage door operator you have to read up on it too. There's a paragraph there to match up a new transmitter with the door operator. Sometimes it complicated, sometimes it's easy.
Rob
I had the same problem with my 07. Finally found the fix! I programmed it a few months back.
Does the LED on the visor have a image of a house? If so, you have the homelink and you are in luck.
This is what I did:
1. Press outer two visor buttons simultaneously for 2 seconds
2. Now hold down one of the buttons (the one you want to open the door), at the same time holding down your existing garage door opener remote next to the visor, until the LED on the visor blinks rapidly (now the visor is programmed)
3. Now go to the garage door opener head unit and press the learn button
4. Now back in the car repeatedly press the the button you held down until the garage door opens/closes
5. Done
You may wish to investigate the type of garage door opener on your house...some car units are not compatible with some house units...the type you need to look for are rolling code...
I suggest you visit this site for more info HomeLink
