Safe winter storage of Z06 tires
2016 Z06
Just wondering if anyone knows what temp you should keep my Z06 stored at so I don’t do damage to the Michelin tires thanks
I keep mine in the basement which stays about 65 degrees F. Never had a problem with them.
Kept mine on 2 c7’s in an unheated garage with no issues which in yeg likely got well below zero C at times. The issue with cold temp is driving on them not just sitting. -7c is what min temperture is to avoid when driving....but if you’re worried taken em off-and bring them in........
You are good anywhere above 0. Below 0 storage is ok on or off your car but don't move the car or tires around if loose until they warm up naturally. (don't heat them with anything)
Got a nice new set with cracks and one set on the car. 3rd winter the car is in YEG winter unheated detached garage and all .ok so far. No cracking.
Great tires but a bit fragile for sure.
Thanks guys I am located east of Edmonton and I always keep my shop at +10C or higher as I store stuff that cannot freeze so I guess I should be fine just didn’t want to make a rookie mistake
You are golden.... everything will be fine with your tires.:thumbs:
A greater issue than the temperature is the surface you park/store the vehicle on. Concrete/cement wicks moisture out of rubber when in direct contact. To alleviate this issue put a piece of carpet (or rubber) under each tire and you can also increase the tire pressure to 48psi which is good for tires that sit in the same spot for awhile.
Ya pretty sure that’s well covered in many threads although nobody I can remember mentioning the Wicking of moisture out of the rubber. Been a few saying they just park the car on the concrete although most do park on something that gives a bit for shape retention. Overinflating is not something I do as I park on a rubber mat. Lots of debate about overinflated storage but nobody reporting any negative effects one way or the other.
least we now know what you are doing. As long as it works for you.
To prevent flat spotting tires that remain on a vehicle in storage fill the tires to maximum pressure (listed on sidewall) or close to it then just rotate wheels/tires 1/4 revolution every month or so (be sure to have carpet or rubber under each tire to keep the concrete from wicking moisture from the rubber). If you store the vehicle on jack stands be sure suspension is loaded not hanging unloaded and no need to remove wheels/tires at that point.
Absolutely should not touch the factory PSS or SC2 Michelin tires if the car is in below 0 storage. (Like many are)
Rolling them will result in cracks.
Above 0... whatever blows your hair back is fine.
