Rear Axel Nuts
2007 Corvette Basic
Replacing rear axel nuts on my 2007 as per TSB 07-04-95-001a which states to torque nuts to 160 ft lbs. Getting feedback that torque should be 140 ft lbs. Any one able to substantiate correct torque.
Regards
Skip74
Did you use new nuts and Loctite 272 As per SB?I split the difference and torqued to 150 and used Loctite.Will use old nuts and double nut.Thanks for the reply
Skip74
