M
MKC8
That's what I figured, but maybe someone else knows better?I'd think you'd see the icons if it did shift to v4.
I'm going with your evaluation, though.
No icons, no AFM.
So, Track, Manual, Z Modes disable AFM.
Where is the V4/V8 icon in your DIC in Manual Mode (not My Mode)?My '23 in MM still has goes into V4.
Today going down the highway I was monitoring things and was noticing the v4 indicator on when the TX was in 7th and because I have been varying speed in about 5 kph increments between 80 and 120 at one point approaching a hill gave it some gas v4 immediately disappeared and v8 shows . When I crested the hill and v4 appeared again I could both feel and slightly hear the difference as it reverted to 4 cylinders. No stereo on at the time. I think if you had the tunes cranked you wouldn’t hear it but would feel the slight difference if you had noticed it before.Some say there is a noticeable noise when it switches. I notice nothing.
I have never noticed/felt/heard the change, only see the DIC V4/V8 indicator, when it's there.Today going down the highway I was monitoring things and was noticing the v4 indicator on when the TX was in 7th and because I have been varying speed in about 5 kph increments between 80 and 120 at one point approaching a hill gave it some gas v4 immediately disappeared and v8 shows . When I crested the hill and v4 appeared again I could both feel and slightly hear the difference as it reverted to 4 cylinders. No stereo on at the time. I think if you had the tunes cranked you wouldn’t hear it but would feel the slight difference if you had noticed it before.
It is very subtle but if you watch for it you will notice it. Seems to be more noticeable when there is load on the motor when you ease off the throttle such as the situation I described above. I will watch for the fuel economy number. In what way does it change?I have never noticed/felt/heard the change, only see the DIC V4/V8 indicator, when it's there.
+ under V4, - under V8.It is very subtle but if you watch for it you will notice it. Seems to be more noticeable when there is load on the motor when you ease off the throttle such as the situation I described above. I will watch for the fuel economy number. In what way does it change?
Taking your foot off the gas also disables v4at one point approaching a hill gave it some gas v4 immediately disappeared and v8 shows .
Perhaps so . Didn’t notice but will check tomorrow. Doesn’t seem to make sense on the face of it. I wonder if the behaviour of it has changed with successive model years…..Taking your foot off the gas also disables v4
Not perhaps! FACT! Though it may not be with newer models. I can't speak to those.Perhaps so . Didn’t notice but will check tomorrow. Doesn’t seem to make sense on the face of it. I wonder if the behaviour of it has changed with successive model years…..
OK !Not perhaps! FACT! Though it may not be with newer models. I can't speak to those.
I can verify that V4 on the dash turns off instantly when off throttle on my 2024.Not perhaps! FACT! Though it may not be with newer models. I can't speak to those.
Some hear / have a noise. Some (ME) don't. Weird!Why disable it you wonder?> Well, because of the loud ugly sucking noise when it shifts into V4. That’s why!
It may “have progressed greatly from the early 2000’s”, but it still sucks.
Literally.
Same here, 2 C8s no noise, no problemsI never hear anything at all when it swicthes either way. I have had two C8s and neither made noise.
Still following as a C7 manual transmission owner. To answer 1st Vette’s question there was a significant issue with C7’s that was narrowed down to operating as a V4, with valve guides failing and I also believe some direct valve damage. Chevy, of course, refused to honour any warranty claims, at least initially. Quite a few C7 owners with the automatic transmission would keep the car in manual mode which was the only way to disable AFM unless you bought a Range device for the OBD port as a workaround.Tap the gas and you get all eight right away. Don’t know why people are complaining.
That was the first thing I did on my Camaros. I actually made my own. It was just a resistor inline with the wires if memory serves. That drove me absolutely bonkers! Now you know why I am the way I am!Now the only thing that bugs me is the 1->4 skip shift (another GM fuel economy “benefit”), I’ve got the bypass harness to disable that but haven’t had the opportunity to install it yet.
