Pre ignition
2024 C8 coupe
NT
The dreaded rattle. I have access to 91 octane fuel only in my area . I have been using only Shell Top Tier 91 since new mostly except while traveling, but always at least 91 and always Top Tier . Yesterday while going to move to the right hand lane while in 4th gear at about 1400 pm I noticed the blind spot lights come on in my right mirror and gave it some gas to quickly get ahead of the vehicle beside me . And then heard very distinctly the dreaded "rattle" . First and only time it has happened.
Has anyone else experienced this ? And is anyone aware of an octane additive that is " approved " for use in the LT2 engine ? And if so have any of you used one . Thanks .
I should add that I was in auto mode which I do infrequently, usually always in manual and generally keeping the RPM up . So , although I didn't notice I am pretty sure it would have been in 4 cylinder mode at the time .
DRIVE IN MANUAL MODE. LOL....
4cly at 1400 rpms. 😬
Believe me , 98% of the time I do . I never let the engine lug . Don't forget that supposedly the ECM won't allow the engine to lug either according to what the engineers/programmers feel is too low . Next time you are in manual mode at 1500 RPM try to up shift .... it won't. Same as trying to downshift at higher RPM , it won't let you.
I suspect you fooled the tranny. It's happened to me occasionally where the car was in the wrong gear when I went to pass. I had been slowing down behind a slow car and the tranny obviously was down a gear, but I sped up a little to check for the pass and the alternate clutch went up a gear and I bogged when I gave it gas. I didn't notice a rattle though.
They will sometimes do that if you are in manual and you happen to pull the left paddle just as the ECM decided it's time to go down a gear like from third to second and you end up in first if the revs are low enough, because of the timing . In manual as you have probably noticed the TX will down shift when the revs drop low enough whether you pull the paddle or not . This though was a definite pre ignition rattle. Very distinct . Not odd shift point related I'm afraid.
I meant that when the car bogs you can get piston rattle
