PTTaylor Casual User You're 5 Jul 1, 2018 48 6 VetteCoins 827 Car 2007 C6 Convertible Jul 16, 2024 #1 What Fluid from Canadian Tire can I use instead of the GM Power Steering fluid.....I do believe that synthetic is NOT an option...correct ?
Murray20c8 Raccoon hunter Staff member Power User Moderator You're a Donor You're Liked Completionist Award You're a Regular CreditBags Seriously Rich Mar 4, 2020 9,436 10,008 VetteCoins 219,704 Car Little red 2020 C8 Province ON Jul 16, 2024 #2 I don't see why you can't use synthetic fluid and any of the ones C.T. sells will likely be fine. Do you have a leak?
PTTaylor Casual User You're 5 Jul 1, 2018 48 6 VetteCoins 827 Car 2007 C6 Convertible Jul 16, 2024 #3 Murray20c8 said: I don't see why you can't use synthetic fluid and any of the ones C.T. sells will likely be fine. Do you have a leak? Click to expand... No leak....just a little low. Everything I've read says do not use synthetic so I am a little confused.
Murray20c8 Raccoon hunter Staff member Power User Moderator You're a Donor You're Liked Completionist Award You're a Regular CreditBags Seriously Rich Mar 4, 2020 9,436 10,008 VetteCoins 219,704 Car Little red 2020 C8 Province ON Jul 16, 2024 #4 PTTaylor said: No leak....just a little low. Everything I've read says do not use synthetic so I am a little confused. Click to expand... I couldn't see anything that said GM's was or was not synthetic, but I always thought it was semi synthetic. You just don't want the oil to compress obviously so I can't think of a reason to not use synthetic.
PTTaylor Casual User You're 5 Jul 1, 2018 48 6 VetteCoins 827 Car 2007 C6 Convertible Jul 16, 2024 #5 OK...thanks for the info. Reactions: Murray20c8
