tires have 5000 miles on them..thanks so muchI would think it is a good idea. Age and heat can diminish performance IMHO. While you are at it might want to check the tires if they are still original equipment.
cant find part 14169 from them? found wiring though $88+1 to change. $88 for Oem here....some cheaper. Betting dealer can’t touch this price...
2006 CHEVROLET CORVETTE 6.0L V8 Spark Plug Wire | Shop Now at RockAuto
Ignition Parts and More for Your 2006 CHEVROLET CORVETTE at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.www.rockauto.com
That is the OEM plugs for my 06 vette..Thanks againNot sure what 14169 is referring to but if it’s the spark plugs they have a vast array from super cheap to very pricey ruthenium!!
Thanks..41 169 - only GM OEM for meIf it was me, I would go for a good set of aftermarket to get a bit of better spark.
Don't forget the boot grease when you change them out.
With regards to your tires, age and sunlight will kill them just as well as wear.
ThanksPersonally wouldn’t change the wires.....plugs ok(but are probably fine). Plug wires are either good or bad. Like to leave things OEM until the break. Did tune up and electrical for many years and would change a wire if it was bad, but that’s it.
Taylor blueHad slight intermitant miss. Went with OEM plugs but added Taylor 10.4's for wires. Miss gone, probably a plug but, dang, those wires look good.
Taylor Reds for me. Better matches the Daytona sunset orange metallic.Taylor blue
mine is lemans blue...will match my 06Taylor Reds for me. Better matches the Daytona sunset orange metallic.
