plugs and wires
Tim C.
You're 5 C6 You're a Regular
Corvette 2006 Coupe
My 06 LS2 has only 47k on it but it is 13 yrs old..Want to change plugs and wiring. AC Delco OEM i am looking at. good idea because of age? Thanks guys.
I would think it is a good idea. Age and heat can diminish performance IMHO. While you are at it might want to check the tires if they are still original equipment.
tires have 5000 miles on them..thanks so much
Not sure what 14169 is referring to but if it’s the spark plugs they have a vast array from super cheap to very pricey ruthenium!!
That is the OEM plugs for my 06 vette..Thanks again
If it was me, I would go for a good set of aftermarket to get a bit of better spark.
Don't forget the boot grease when you change them out.
With regards to your tires, age and sunlight will kill them just as well as wear.
Thanks..41 169 - only GM OEM for me
Personally wouldn’t change the wires.....plugs ok(but are probably fine). Plug wires are either good or bad. Like to leave things OEM until the break. Did tune up and electrical for many years and would change a wire if it was bad, but that’s it.
Thanks
Has anyone used Taylor 79613 high performance wires LS2 vette (blue) good match for my Lemans blue
