Original Tires shaking after 12 years ? Is that possible that I need to replce the old tires. It happens if I go up over 120
I have run on 20 year old tires with no problems.. Check the tires closely and if they are in good condition have them balanced and continue . But if you don't feel comfortable with them replace and carry on. It's your call...
I agree with you and Murray. There was a time when we never heard anything about changing tires every 6 years. Indeed, we were taking worn out tires back to tire shops and having them re-treaded. That practice is still common, especially with commercial highway haulers. So next time you are passing a tractor trailer on the highway you can think about ho many years and miles are on his tires.
My tires came with my Corvette in 2015. They still have a solid 5/32 tread remaining. When no on the road, they are out of the sunlight and cold temperatures in my heated and humidity controlled shop, sitting on rubber cushions. I inspect them regularly for any abnormalities. I do not plan on changing tires on any of my vehicles based only on how old they are.
The Truth About Tire Lifespan: Debunking the Myth of the 6-Year Rule​
As the only part of a vehicle that touches the road, tires are crucial for safety and performance on the road. But just how long can you expect your tires to last? The answer can vary depending on a number of factors, such as driving habits, climate, and maintenance practices. While some experts recommend replacing tires every six years, many tires can last much longer than that with proper care and attention. In this article, we’ll explore the factors that affect tire lifespan and how you can maximize the life of your tires.
Tire lifespan is a complex topic, as many different factors can affect how long a tire lasts. Generally speaking, most tire manufacturers recommend replacing tires after six years, regardless of their mileage. This is because even tires that are used infrequently can degrade over time due to environmental factors like sunlight, heat, and humidity.
However, there are many instances where tires can last much longer than six years. For example, if a vehicle is only driven occasionally and stored in a climate-controlled environment, its tires may last for ten years or more. Similarly, if a tire is used in moderate temperatures and is regularly inspected and maintained, it may last longer than the typical six-year lifespan.
One of the biggest factors that affects tire lifespan is climate. Extreme heat, cold, or humidity can cause rubber to degrade more quickly, which can lead to cracking, dry rot, or other forms of damage. This is why tires that are used in hot climates or areas with high humidity may need to be replaced more frequently than tires used in more moderate climates.
UV radiation from sunlight can also contribute to tire degradation. The sun’s rays can cause the rubber to dry out and become brittle, which can lead to cracking and other forms of damage. This is why tires that are stored outside or parked in direct sunlight for long periods of time may degrade more quickly than tires that are stored indoors or in a garage.
Another factor that affects tire lifespan is driving habits. Aggressive driving, excessive speeding, and hard braking can all put extra stress on a tire, which can lead to faster wear and tear. Similarly, if a tire is overloaded or underinflated, it may wear out more quickly than a properly inflated and loaded tire.
Regular maintenance can also help to extend the life of your tires. Regular inspections can help to identify any signs of wear or damage early on, which can allow you to address the issue before it becomes more serious. Additionally, regular tire rotations and alignments can help to distribute wear more evenly across all four tires, which can help to extend their lifespan.
In conclusion, while it’s true that tires can degrade over time due to a variety of environmental and usage factors, many tires can last much longer than the typical six-year lifespan with proper care and attention. By keeping your tires properly inflated, driving responsibly, and performing regular inspections and maintenance, you can help to extend the life of your tires and maximize their safety and performance on the road.
I've also had the stock Goodyear Eagles on my Camaro that lasted just 3 years. Chunks out of them. Terrible tire.
Snows don't seem to last very long before they get hard quick.
I've had brand new Firebird take-offs from SLP when they did the Firehawks that I stored in the barn and they were still virtually good as new after 8 years.
Yes but all the tire manufacturers and tire sales locations recommend new tires every six years. I just don’t know what I’m going to do, lol. Years ago we drove around, when we had enough change to buy a couple of gallons of gas, on tires with canvas showing. Yes we eventually got flats but never had one “ blowup “ . I don’t know that I would go out and do any high speed driving on questionable tires but for daily driving no big deal IMHO .
And guess what they want you to do. ;)
