OEM Z51 EXHAUST TRANSFORMATION
2021 c8 corvette
Cut the restrictive 2.25''outer pipe tip to 2.75''
Are you out of warranty? If you weren't before, you probably are now. ;)
Interesting choice of things to modify.
Assume it sounds good? If that was the impetus. Or has the horsepower/torque improved?
Inquiring minds want to know, how did you get to the point where you said, I am pulling off this NPP setup and will try to make it better. And how did you know that going from 2-14" to 2-3/4" was the sweet spot for flow ?? Was there an assumption that by opening up the diameter to 2-3/4" you would get better flow, performance, sound ?? Curious to know the specific reasoning here. I guess cheaper than going aftermarket, but the engineering side of me is curious to how you got to this point and the decisions made along the way. Thanks !!
