Went to start the car this morning. Turn the key lights all come on as normal. Turn the key nothing, no click no attempt to start. Put a battery charger on it, waited about 29 minutes still nothing. Can anyone suggest what might be wrong please?
Thanks but it’s a 6 speed standard.If its an automatic, try pushing the shifter up in park harder., that might work.
I tride both keys after cleaning them, still nothing. Tried boosting stil nothing. I’m at a l,oss of where to go from here…Sometimes the ignition key dirty need to clean . Or try the spare key sometimes the old key chip get weak
How do I check this switch to know if it’s working or not?You may want to check the lockout switch at the clutch lever.
Ensure a fully charged batteryWent to start the car this morning. Turn the key lights all come on as normal. Turn the key nothing, no click no attempt to start. Put a battery charger on it, waited about 29 minutes still nothing. Can anyone suggest what might be wrong please?
Thank you, where is this fuse box located exactly?Go to fuse box under passenger side. Look for fuse 10M for crank (CRK) l think number (14 ) check that fuse if it's good l think the fuse it's the problem
i think I do hear the fuel pump. Thanks, I’m going to check the #14 fuseJust to pile on something else, when you turn the key to the on position can you hear the fuel pump? If the VATS system
detects a fault or error, you'll get a no fuel pump and no starter condition. Are you having fun....yet.
Fuse box under glove box passenger sideThank you, where is this fuse box located exactly?
