For the thrifties, that would work. If I had hockey tape around the house it might be a solution, but at $11 for a roll, I am already half way to having the proper tool.Or you can put a couple of wraps of hockey tape on the end of a regular socket...
I also like the fact that these have a nylon insert that protects the head of the lug nuts especially we using the impact gun to install and remove.
None of my sockets were 6-point so, I opted to spend $22 to protect the $300 worth of lug nuts and $3000+ dollars of rims.
It is also the perfect length to miss the body panels when using the 250ft/lb torque wrench to loosen and tighten up the said lug nuts.
