C6Vette09
C6Vette09
Active Member
Dec 20, 2009
199
1
GTA
2009 C6 coupe
How far did you guys/ gals lower your rides? I was told that the lower bolts from WCC are only good for a limited period and it would be better to slightly modify the stock bolts because they are stronger?
You can lower the front on the stock bolt more than enough . The rears you will need the longer bolts , as this is a much better and safe way of lowering the rear.
Thx
[email protected]
Lowered on stock bolts and that is far enough, if you go too low the speed bumps and pot holes will just kill the front end.
I trimmed the front air deflector by about 1-2" as it was always hitting on my driveway entrance.
