Lowering your C8?
Yes that is exactly what I am saying. When you install the kit for the front it lowers it aprox 1 inch however when you lower it in the rear via the adjustable struts set at the lowest point it lowers it probably 1 1/4 inches to 1 3/8 inches which for me is too low when entering and exiting some parking lots as I raise the front lift causing the back to be at a greater angle resulting in the rubbing issue no matter how slow I am going on certain grades.
Where did you get that license plate frame...I really like it
Where did you get the license plate frame?
Got my car back today. It's not as low as I'd like. Better than before, hopefully it settles a bit more over some time. My tires also make a difference cause my side walls up front are 30 (stock 35) and rear is 25 (stock).
